Actual length of power and ground cable?? - FirebirdV6.com/CamaroV6.com Message Board
  • Actual length of power and ground cable??
    what is the actual length of power and ground cable did you guys use?? Thanks
    Past Ride
    1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
    (If you dont know me, you haven't had a V6 long enough)
    Current Ride
    2006 Mitsubishi Evolution GSR
    www.myspace.com/shane1015
    I used 17 feet of power wire from battery to the amp rack on the inside rear of the t-top storage. Took every inch of it. I used about a foot of ground from the amp to the ground point on the truck release. I guess the major factor is how far from the battery you are, my spot couldn't be much further.
      keep the ground cable to 10"'s or less, it's just better that way.
      -Steve
        The power I used a 20' ground like 15".
        2001 Blue Firebird.<br />V6 M5. free ram air mod, 3\" pvc intake, Air temp module, 3\" exhaust, Dynomax 3\"straight through exhaust, O2 sim with off road pipe.<p>Kenwood kdc-mp919 head unit, kfc-628 and kfc-748 amps, Kicker I650 mids/highs, 12\" kenwood WS-303 sub<br /><a href=\"http://www.trafficjamzcaraudio.com\" target=\"_blank\">www.trafficjamzcaraudio.com</a><p>1500 years ago the world was the center of the universe. 500 years ago the world was flat. 15 minutes ago we were alone on this planet. Just think what you will know tomorrow.
          I didn't measure, but I used just as much 4awg as I needed to wire it from the battery to the rear hatch. and about 15" or so of ground wire. Keep the ground wire as short as possible.
          -Mike
          <b>Trucks</b> <br />\'05 Dodge 3500 Dually <i>Cummins Turbo Diesel</i><br />\'98 Dodge 2500 4x4 <i>360 V8 (Wife\'s)</i><br /><b>Toys</b><br />\'81 Chevy K10 <i>Stroker/Swampers/Custom Suspension/1-Tons/Beadlocks</i><br />\'99 Camaro Z28 <i>6 Spd, T-tops, Borla</i><br /><br /><b>Real trucks don\'t have spark plugs</b>
