Alright, I managed to find that vss wire..Or at least I'm fairly sure, the problem is that both the vss connection and reverse light connection are not reading on my gps.I know for a fact that the reverse light wire is the right one because I tested the light itself. But when running the test on the unit itself it shows no activity for that wire. I'm at my wits end. Each wire has a requirement according to the install manual. I'll list them here in the hope that someone might be able to enlighten me as to what the problem may be. Oh yeah, the vss is connected to the green/white wire just before the gauge cluster and the reverse light is plugged in at the passengers kick panel. Here are the requirements as it states in the booklet:
VSS- square wave
input pulse frequency -0Hz to 2.5kHz
input voltage range -13 to +26 Vmax
Low level voltage Vl max .9VL max
High level voltage VH min 4.0 VH min
Yellow (sine wave) sine wave
Input pulse frequency 1 Hz to 200 Hz
Input voltage range -13 to +26 Vmax
And this is for the Reverse Light
+13.8 V DC nominal (When vehicle in reverse)
Low level voltage VL max 1.0 VL (max)
High level voltage VH min 7.0 VH (min
Now I have no idea what any of this means. My guess is that I use the navmates green wire for a square wave and yellow for a sine wave. Currently I'm using the green wire.. Not that I know what either of those mean, but hey. The reverse light problem makes no sense. If anyone can clue me in to what I can do or what the problem might be please please let me know. Thanks greatly.
VSS- square wave
