is this system gonna work.. - FirebirdV6.com/CamaroV6.com Message Board
  • is this system gonna work..
    clarion HU (forget number,) 50x4 watts on the HU tho, 2 10' MTX Terminator subs in orig. box, 10' rockford punch XLC, and a Jenseen 1000/1200 watt amp
    just outa curiousity, will this hook up right? I got it all free from my dad (when he used to be used car manager last year). I know the HU and subs work, pretty sure amp works too
    1991 firebird - sold<br />1994 camaro v6 - lady ran red light<br /> *totaled*<br />1996 Camaro v6 RS sport package 5 spd - 8mm wires/ platinum plugs, z28 clutch@assembly, powerslot rottors, hiPo brake pads, hiPo power steering pump, larger tie rods and hubs, 1le tranny mounts
    it should work
    ya still need cables for the amp. If you have a monsoon things might get a bit complicated
      My car had the Bose system in it when I got my car. Can you guess what I did with it since I used the word "had"? :D That's right, I ripped the factory stuff out and started from scratch. At first I just added a head unit and used the Bose speakers. They didn't cut it for me. They would just about get loud enough for the car next to you to notice, then they sounded over-exerted after that. If you want to use that 4-channel amp with your factory speakers, I wouldn't bother. They come from the factory with as much wattage as they can handle. To go louder (and clearer in my case), you'll be more satisfied if you re-do the whole thing.
      But, this is just my opinion. :D
      95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
