Door lock problem please help - FirebirdV6.com/CamaroV6.com Message Board
  • Door lock problem please help
    OK this is my first chevy ever so please be patient with me because i will have lots of questions in the future im sure.
    I have owned mustangs all my life but I traded a 900 dollar truck for a flawless 00 rs so why not huh.
    Any way my problem is my power door locks act freaky. I can lock them using the switch on the doors inside but they will not unlock. If i use the key fob only the drivers door unlocks no matter how many time i push the button.
    When i hit the unlock button on the door i can hear something clicking in the dash so I know the switch is good. PLease help me with this problem.
    Thanks
    I am on the market for performance parts.<br />let me know what you have
    Check to see if the plastic sliding piece that you manually use to lock and unlock the doors isn't getting jammed. It should slide left and right smoothly. But I'm guessing you probably have a bad actuator.
    2006 Tiburon
      I have this problem in my firebird. I can lock them fine but not unlock them with the power lock button. I think this is a pretty common problem on f-bodies of this generation. If you really cant fix it then just buy a new switch for 20 dollars online.
        thanks guys
