HELP! Converting 2001 camaro tail lights to 97- sequentials - FirebirdV6.com/CamaroV6.com Message Board
  • HELP! Converting 2001 camaro tail lights to 97- sequentials
    I'm converting my 2001 Camaro to 97- tail lights and need help figuring out the new connection under the dash to make the brake and turns work together. people have said that you connect the light blue wire coming out of the brake switch to a white spare wire coming out of the steering column that is not connected. I can't find that white wire. Is it up inside the column and I have to take it apart to get to it? There are two white wires but they are both connected. I don't hink either of these are it. Anyone done this conversion. Help please!! :(
    Thanks..
    We can save a lot of time if you just assume I know everything...<br /><br />SXS Camaro - <br /> <a href=\"http://www.cardomain.com/memberpage/703383\" target=\"_blank\">http://www.cardomain.com/memberpage/703383</a> <br />or <a href=\"http://home.tampabay.rr.com/whitewrld/\" target=\"_blank\">http://home.tampabay.rr.com/whitewrld/</a>
    I cheated...
    have you done a search on this site yet. I wrote up a small writeup on how I did mine.
    I didn't touch anything under the dash, I did all my connections to the harnesses in the tail lights themselves.
      http://www.camarov6.com/ubb/ultimate...=007482#000000
      http://www.camarov6.com/ubb/ultimate...=007402#000000
      http://web.camaross.com/forums/showt...ght=conversion
      I think that covers what I did
        Thanks but I need to do the conversion under the dash in order to set the sequentials up right. I knew about the Dark angel article but can't locate the spare wire that he mentions as connecting to the brake wire. Thanks!
