Which side for Turn on lead? - FirebirdV6.com/CamaroV6.com Message Board
  • Which side for Turn on lead?
    Hi, I have routed the power cable on the passenger side and the rca cables are on the drivers side. Which side should I put the blue turn on lead. Some say to keep it with the power wire to prevent noise and some people say it doesnt matter just put it with the rca cables. I dont want to take this apart again so which side worked best for you. Thanks for your help.
    1995 3.4L M5 Camaro<br />Bullet Performance Exhaust, K&N FIPK, Stage 1 clutch, Short shifter, Hotchkis STB, Taylor Ignition wires, NGK spark plugs
    Mine is run down the drivers side. As long as you have a good set of rca's it will be fine.
      Regardless of RCAs it will be fine. The remote wire has a minute amount of current running through it. Infact, many RCAs cables come with a remote wire built in!
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
