I grounded my amp using the bolt that the rear seat latches on to. I removed all the paint and the terminal is infront of the washer. Is this an ok ground. I was gonna use the rear seatbelts but when i took the bolts off i didnt see alot of metal that i could connect to. Also is it ok to run the ground wire next to the power wire. Thanks
Is this ok for a ground?
