Alright well i'md doing comp in USAC and i'm hittin in the 148.8 to 151.1 range depending on meter and weather conditions with either amp the spl is identical on them days one amp runs 0-150 class and the other is 151-300 stock classes so that means i've exceeded the limits of my box i need some help building a new box for finals i wana be able to hit a 155 at least so i can get in the top 5 but i need to stay in the stock catagory
which means the box has to stay below the window line and behind the seat along with the equipment so any suggestoins on dementions and if you know what i can get outta it i wana keepo the 2 12's that i have already if you wana see the my current setup check out the sig or look for boboboom2 on sounddomain.com or this link if it works for you Boboboom2 96 camaro RS any and all input would be appricated thanks :cool:
