94 Stock wires... what color does left front and left rear? - FirebirdV6.com/CamaroV6.com Message Board
  • 94 Stock wires... what color does left front and left rear?
    basically my stereo got jacked a month ago I finally fixed the wiring and installing my stock tape deck.
    I pretty much wired wire for wire together color mathcing.
    Everything works except the left front an maybe the left rear(has no speaker in the hole) work. Jsut curious what colrs they are I may have mixed up a 2 yellows and two browns, that looked similar.
    Thanks.
    __________________
    Headunit wiring harness
    Pin#............Color.................Function
    1......................Grey....................... .Front Left Speaker -
    2......................Tan........................ ..Front Left Speaker +
    3......................Dark Green.............Front Right Speaker -
    4......................Light Green.............Front Right Speaker +
    5......................Black .....................Ground
    6......................Brown.....................I llumination
    7......................Grey....................... .Dimmer
    8......................Pink....................... ....Power Antenna
    9......................Yellow..................... 12V Ignition
    10....................Orange....................12 V Constant
    11.....................NA......................... ..NA
    12.....................NA......................... ..NA
    13.....................NA......................... ..NA
    14....................Dark Blue................Steering Wheel Controls
    17....................Light Blue............... Right Rear Speaker -
    18....................Dark Blue................Right Rear Speaker +
    19....................Yellow.....................L eft Rear Speaker -
    20....................Brown......................L eft Rear Speaker +
    The smaller plug on the back of the radio is for the optional cd changer.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      THakns all the info I needed, I think I got them mixed up with the speakers and the illumination...
