Anybody know the dimensions of the stock monsoon amp by chance? I dont have my car right now so i cant measure it but i kinda want to know. Thanks.
Monsoon amp size
Monsoon amp size
2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhardTags: None
Think I could mount an amp that is 12x10x2.25 back up in there? Also how bad of a spot is it to put an amp for heat and such? I just want to keep my amp out of the way this time.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
you have monsoon?
wanna trade some monsoon speakers for some decent real speakers(6x9)-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
I dont really want 6x9's but once i get all my other stuff swapped out I'll let you pick up my monsoon stuff cheap.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Originally posted by T-Punk:
I dont really want 6x9's but once i get all my other stuff swapped out I'll let you pick up my monsoon stuff cheap.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
I'm working on it. Its just a small system of an ED Nine.4 amp, a pair of Edi 6000s, and a pair of Eu 700's with an old alpine 7969 Hu. It will sound decent but will hav no thump. I'm going for a light weight system that sounds decent and i dont think i can do any better than that. What speakers do you want anyway, I might be able to go ahead and take them out depending on which ones you need.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
I have my nine.4 mounted on my amp rack and is wide open, and it gets pretty hot. the nine.4's do run pretty hot esp compared to the nine.1.
i have the edi6000's, edu600's, and nine.4. it gives pretty good thump for just a reg speaker setup, with the subs off. the eu 700s will def give you more bump than my 600's. which vc setup are you going with on the 700's?<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
dual 4ohm so that i can get a 2ohm load to them which will give them 100wrms each from the Nine.4.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Thats what i figured. I plan on doing the same thing. Ill swap out my 600s and get the 700's.<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
