Monsoon amp size - FirebirdV6.com/CamaroV6.com Message Board
Monsoon amp size
  • Monsoon amp size
    Anybody know the dimensions of the stock monsoon amp by chance? I dont have my car right now so i cant measure it but i kinda want to know. Thanks.
    I don't have access to one at this time either, but I can give you a pretty decent guess of 10"L x 7"W x 2"T. Yep. It's a small little thing.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      Think I could mount an amp that is 12x10x2.25 back up in there? Also how bad of a spot is it to put an amp for heat and such? I just want to keep my amp out of the way this time.
        you have monsoon?
        wanna trade some monsoon speakers for some decent real speakers(6x9)
          I dont really want 6x9's but once i get all my other stuff swapped out I'll let you pick up my monsoon stuff cheap.
            I have my monsoon out, and I was able to fit 2 pioneer 120w stereo amps on that panel on both sides.
            If someone would come to my place I would give up all my monsoon for free [img]smile.gif[/img]
            ps , I dont have a background noise anymore.
              well hurry up and by the stuff.
                I'm working on it. Its just a small system of an ED Nine.4 amp, a pair of Edi 6000s, and a pair of Eu 700's with an old alpine 7969 Hu. It will sound decent but will hav no thump. I'm going for a light weight system that sounds decent and i dont think i can do any better than that. What speakers do you want anyway, I might be able to go ahead and take them out depending on which ones you need.
                  I have my nine.4 mounted on my amp rack and is wide open, and it gets pretty hot. the nine.4's do run pretty hot esp compared to the nine.1.
                  i have the edi6000's, edu600's, and nine.4. it gives pretty good thump for just a reg speaker setup, with the subs off. the eu 700s will def give you more bump than my 600's. which vc setup are you going with on the 700's?
                    dual 4ohm so that i can get a 2ohm load to them which will give them 100wrms each from the Nine.4.
                      Thats what i figured. I plan on doing the same thing. Ill swap out my 600s and get the 700's.
                      • 187shark
                        by 187shark
