Need help on changing steering wheel radio control lights - FirebirdV6.com/CamaroV6.com Message Board
  • Need help on changing steering wheel radio control lights
    my right steering wheel light has been out for a month now
    i'd really like to change it
    but how?
    can someone PLEASE help me??
    1996 Polo Green Metallic Firebird V6 3800 A4 - <i><a href=\"http://personal.bellsouth.net/lig/j/h/jhooks2/index.html\" target=\"_blank\">The Green Goblin</a></i>
    I wish I knew...my left side is out as well...hopefully someone will reply to this topic
    2002 NBM Firehawk #312 | <a href=\"http://hawk.visionsconnect.com\" target=\"_blank\">hawk.visionsconnect.com</a>
      i have the same problem, someone must now how to fix this :(
        I'd imagine the battery needs to be disconnected, so the air bag doesn't get screwed. They're probably LED's. Anybody have part numbers on these lights?
        Massivefirebird\'s <a href=\"http://www.cardomain.com/id/leondb\" target=\"_blank\">(leonDB) Cardomain</a><br /><a href=\"http://www.flowmastermufflers.com/cgi-bin/flowmaster\" target=\"_blank\"> Flowmaster 80</a>, <a href=\"http://www.knfilters.com/\" target=\"_blank\"> K&N FIPK</a>, <a href=\"http://www.jetchip.com/\" target=\"_blank\"> Jet Stage 2 & 180º T/S</a>, <a href=\"http://www.boschusa.com/AutoParts/SparkPlugs/PlatinumPlus4/\" target=\"_blank\"> Bosch quads</a>, <a href=\"http://www.pilotautomotive.com/pilot2dn.htm\" target=\"_blank\"> Pilot 1055 Fogs</a>, <a href=\"http://makotoautotrends.com/\" target=\"_blank\">Clear turn signals</a>, <a href=\"http://www.autoventshade.com/\" target=\"_blank\">AVS rear blackouts</a>... <a href=\"http://www.massiveaudio.com\" target=\"_blank\">2 Massive CW 12\'s</a>, <a href=\"http://www.kicker.com\" target=\"_blank\">Kicker 2252, 652,& 352 XI Amps</a>, <a href=\"http://www.mbquart.com/2003/en_US/home/\" target=\"_blank\">MB Quart</a>.
          ok I mailed www.gmparstdirect.com and they gave me to part numbers.
          161
            SORRY ABOUT THE PREVIOUS EMAIL
            I emailed WWW.GMPARTSDIRECT.COM and they gave me two part numbers.
            16191162-for the left control
            16191172-for the right control
            I'm not sure what this includes. The exact words they gave me was, "THEY UNPLUG FRONT THE COMMON HARNESS TO THE WHEEL"
            I have no clue what they mean.
              those part numbers are for the full control. The full control is expensive. If you just want to replace the light you can do that on your own if you have a little do-it-yourself in you. Just pulling the battery terminal is never a bad idea when you're working on something electrical. you should probably pull the fuse for the air bags and/or let it sit for a few (like 15-30) minutes for any thing to discharge. I only did this with my grand prix so I'm not sure if it's EXACTLY the same, but the stering wheel is the same. Just pop a butter knife down the side of the switches and they will pry out. They're held in mostly just by friction so they come out pretty easy. Once they're out, you can replace the whole switch with the switch part numbers, or you can open up the switch and just replace the LED that lights up the switch that is not working. if you're not sure how to do it, take it to someone that does, you might have the wrong voltage LED which might cause some difficulties for ya.
              Hope that helps ya guys. If you find this to not be true with your car, post it, I wanna know about it.
              Mike<br />\'99 Z28 LS1 (383 in the works) M6<br /><a href=\"http://members.fbody.com/drmilhouse/\" target=\"_blank\">stereo pics</a> Almost sold, the amps are still for sale - make an offer.<br /><a href=\"http://members.fbody.com/drmilhouse/paypal.html\" target=\"_blank\">Help Mike pay for his engine. Every dollar helps!</a>
                ok so i take a butter knife and pry the whole control out. how do i disconnect the controls form the wire is there some sort of harness on the back of the controls. I can get the a set of controls for 25 bucks so it should be no problem. if the car is turned off do i still have to pull out the fuse or disconnect the battery.
                  <blockquote>quote:</font><hr>Originally posted by massivefirebird:
                  I'd imagine the battery needs to be disconnected, so the air bag doesn't get screwed. They're probably LED's. Anybody have part numbers on these lights?<hr></blockquote>
                  nope, they are bulbs (with filaments).
                  <b>LS1 RX7! </b> &#0124;&#0124; <a href=\"http://www.no-bling.com/image_galleries/index.php?action=viewgallery&gallery=galleries/eyeoutthere_LS1_FC\" target=\"_blank\">Full Gallery</a> <br /><br />LT1 Header Informtion/survey
