wire harness for Bose system on 1994 Camaro - FirebirdV6.com/CamaroV6.com Message Board
  • wire harness for Bose system on 1994 Camaro
    I'm putting in a JVC head unit with CD and was wondering if the wiring harness in the car has a connector or will I have to cut the wires. I bought an aftermarket wiring connector from Scosche will this work?
    ...........Please read the FAQ.......
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      I checked FAQ myself and didnt see anything in there about it. I'm using a Scosche line output converter to make RCA outputs for my amp. I hope it works!
        As long as the haness is the correct one for your car, you should be fine. That and a dash kit should be all that you need, maybe an antenna adapter. good luck
        Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
          Monsoon or not, this is your answer.
          [ October 11, 2005, 11:54 AM: Message edited by: 96firebird311 ]
          Red 96' A4 Firebird
          Check it out here!
            Thanks guys....I'll tackle this tomorrow. Maybe I'll takes pics now that I have a dig. camera
              Install went well and very easy. Hardest part was wiring the 2 harneses together.
