I'm putting in a JVC head unit with CD and was wondering if the wiring harness in the car has a connector or will I have to cut the wires. I bought an aftermarket wiring connector from Scosche will this work?
wire harness for Bose system on 1994 Camaro
As long as the haness is the correct one for your car, you should be fine. That and a dash kit should be all that you need, maybe an antenna adapter. good luckCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Originally posted by pinball-1:
I checked FAQ myself and didnt see anything in there about it. I'm using a Scosche line output converter to make RCA outputs for my amp. I hope it works!
[ October 11, 2005, 11:54 AM: Message edited by: 96firebird311 ]
