6" LED's - FirebirdV6.com/CamaroV6.com Message Board
6" LED's
  • 6" LED's
    Ok i have two green 6" leds that plug into my cigarette lighter but i dont really want them in there. if i already have a toggle switch hooked up to my battery with my underbody neons on the same toggle. can i just splice the 6" led wires and hook them up too that toggle switch or what? so that way they can go off anmd on and stuff? so can i do that is it that easy?
    !!No Worries!!<br /><br /> <a href=\"http://www.cardomain.com/memberpage/515424\" target=\"_blank\">http://www.cardomain.com/memberpage/515424</a>
    yeh dude, its simple 12 volt power, just cut the cigarette lighter adapter off of it, and splice it into your underbody neon wire. The wire with the white on it will be your positive, the other solid black is your ground.
    Peace
    1996 Pontiac Firebird<br />Flowmaster Exhaust, Custom Cold Air Intake, 3.42 gears with LSD
      2006 Tiburon
        umm ya i have two red ones that are hooked up to my swtich from my underbody neons. theres a ground then im guessin a hot. but now what do i do with the 6 inch ones if they are not color coated how should i hoook them up then? theres a silver metal and a gold metal now what?
          gold is your positive, silver is your ground
            Just to make sure...
            Take apart your 6" neon's cigarette lighter plug and look to see which wire is attached to the 'center' contact pin, this will be your +.
            2006 Tiburon
