Heat - FirebirdV6.com/CamaroV6.com Message Board
Heat
  • Heat
    Has anylne had a problem with heat in there dash after replacing your head unit?
    if so what did you do to solve the problem? :cool:
    Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
    Do you just mean hot cd's? don't worry about it. It's the amp in the back of the deck that's heating up your dash, there is nothing to worry about, it would do it in any vehicle. They tend to do that. [img]graemlins/burnout.gif[/img]
    Teal 94 Camaro 3.4 Liter<br />Transgo stage 3 shiftkit, Shift module, corvette servo, SLP cold air induction,3.42 ring and pinion, Heavy Duty Posi LSD, Flowmaster exhaust, NX, blackouts
      My dash gets hot whenever the lights are on... I don't notice it all the time, though, and im not sure if its only when the lights are on.
      www.RedLineVSix.com || 1996 Camaro, 15.159@92.5mph
        <blockquote>quote:</font><hr>Originally posted by Camaro Bob:
        Do you just mean hot cd's? don't worry about it. It's the amp in the back of the deck that's heating up your dash, there is nothing to worry about, it would do it in any vehicle. They tend to do that. [img]graemlins/burnout.gif[/img] <hr></blockquote>
        yes and also if I am running the unit for any lenght of time and I remove the face plate it is almost to hot to touch.
          My Alpine does the same thing. I think it's normal.
          2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
            ok thanks for the help
              The Sony in my car and the Blaup in my truck both do the same thing....
              <b>Trucks</b> <br />\'05 Dodge 3500 Dually <i>Cummins Turbo Diesel</i><br />\'98 Dodge 2500 4x4 <i>360 V8 (Wife\'s)</i><br /><b>Toys</b><br />\'81 Chevy K10 <i>Stroker/Swampers/Custom Suspension/1-Tons/Beadlocks</i><br />\'99 Camaro Z28 <i>6 Spd, T-tops, Borla</i><br /><br /><b>Real trucks don\'t have spark plugs</b>
