Apline power lead - FirebirdV6.com/CamaroV6.com Message Board
Apline power lead
  • Apline power lead
    Do any of you guys with alpine hu's run a separate power lead to the junction block instead of using the stock red power wire? Alpine reccomends this and i'm wondering if it will improve my sound. I have a 7894 HU on the factory wiring right now. any ideas?
    1993 Camaro 3.4L A4 many mods comin for 2004<br /><br />\"The last thing I wanted was to get in a fight in Jackson, Mississippi on a Saturday night\"
    isn't the yellow wire that is All time power? red comes from the fuse box that way the head unit isn't on all day/night running your battery down. Im probably wrong but thought that was right. ~shrug~
    91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
      First, are you using the head unit's internal amp? Or do you use the RCAs to an aftermarket amp?
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        I've got a CDA-9813. I've got the power lead going to my battery. At circuit city they said it wasnt necessary, but I handed them the wiring and said to do it anyways. I think it's amazing. My speakers go loud and are always clear. Personally, I think the power lead is awesome, it sounds just as good as if there was an amp powering your speakers. How many watts is your deck? Mine is 60watt x 4
        1996 Pontiac Firebird: A4, Flowmaster 80 Series, dual 3\" Stainless Steel tips, SLP CAI, Alpine CDA-9813 deck, Infinity speakers, Alpine Type R sub, MTX Thunder 801d amp, Tsunami 2 Farad Capacitor.<br /> <a href=\"http://www.cardomain.com/id/firebirdfury\" target=\"_blank\">http://www.cardomain.com/id/firebirdfury</a>
          <blockquote>quote:</font><hr>Originally posted by FirebirdHatesRice:
          it sounds just as good as if there was an amp powering your speakers. How many watts is your deck? Mine is 60watt x 4<hr></blockquote>
          I doubt it. And that's 60W PEAK. Probably around 27WRMS.
          Red 96' A4 Firebird
          Check it out here!
            no...the big thing about those alpines is that the 60 watts is the RMS rating.....it ought to be theyre expensive as $hit
              mines 60x4 too and it rocks ...i love it....i'm gonna put in the separate power lead this weekend.
                <blockquote>quote:</font><hr>Originally posted by MississippiMaro:
                no...the big thing about those alpines is that the 60 watts is the RMS rating.....it ought to be theyre expensive as $hit<hr></blockquote>Yeah....I wish it was RMS, but it's not. Here's some info I pulled off the 9813's spec opage for ya.
                Power Requirement / Fuse Type 14.4V DC (11 –16 V allowable) / 20A (ATC)
                Operating Temperature (°C/°F) 60°C (140°F) to -10°C (14°F)
                Maximum Mounting Angle 30° from Horizontal
                Maximum Power Output (Note 1) 60Wx4
                Continous Power Output (Note 2) 27Wx4
                Pre Output Voltage (Before Clipping) 4 volts
                Note 1: Under maximum operating voltage and input signal, into 4 ohm loads
                Note 2: Per EIA-517 standard, 40Hz to 20Hz, 0.8%THD, with 14.4 volt DC Supply
                God damn I'm good. 27WRMS on the nose. Look it up at www.alpine1.com if you don't believe me. And actually, feature per feature, Alpine's are one of the cheapest bangs for the buck.....
                Red 96' A4 Firebird
                Check it out here!
                  Say what you will, but I love my Alpine! Plus, it also helps that I got it $100 off retail price at Circuit City. You can never go wrong buying open box :cool:
