New Install Write up for PS1, TVtuner, LCD Visor. 56K Beware - FirebirdV6.com/CamaroV6.com Message Board
  • New Install Write up for PS1, TVtuner, LCD Visor. 56K Beware
    I finnally got it all installed. Details from this post.
    Update** PS1+ TV tuner + LCD Visor System Going in Tomarrow
    People have been asking for a write up and a review so I will do my best to explain it all here. First I will explain the all the power connections, then I will explain all the AV connections, then I will give my review.
    POWER CONNECTION
    Connection A This is the switch connection. The switch has three prongs, the ground, hot wire, and the accesory wire. The switch in this application is only used to tun on the PS1, since it is powered by an inverter that I didn't want always on. But for other applications, the switch can also simotaneaously be used for other devices. The + prong on the switch is connected straight to the battery, in order to give a constant power. Spliced into the hot wire before the switch is the + for the screen and the TVtuner. I did this because the screen has an automatic signal detecting switch, and the TVtuner has a power button on the remote control. The TVtuner also requires a constant power in order to save the channel memories, and the setting for the Fm-modulator.
    The Accesory prong is connected to the inverter + wire (Connection B)
    The ground prong is connected to the cars ground at Connection C.
    ( The picture shows two wire at connection B, because at this time I had the screen powered by the switch.)
    Connection C At this connection I have all the ground wire connected to the cars ground. On the picture below I circle an area on the pic on the far right, this is the factory ground terminal I used to ground out all my components.
    Connection D This connection is one of the most difficult. My electrical engineering abilities are limited, so I just bought a converter to change the volate from 12V up to 220V then into the PS1 converter down to something like 9 volts. When I bought the converter I did not relize that I could get a car adapter plug for the PS1. So this design will be changing. But I will explain for anyone who might want to use a inverter.
    I found a great place to put the inverter is behind the passenger kick panel, behind the kick panel is a rubber/plastic cross the is designed to support the kick panel. I used a razor and cut it out, and placed the Inverter there. I have had no problems from overheating, and it works fine. In order to get the power to the PS1, I had to use an extention cord because I couldn't fit the PS1 converter plug in that small area. SO i too a 3foot extention cord and cut it down to 6 inches, soldered it together, and taped it up. Then I was able to pug it all together and hide it up behind the golve box.
    [ October 03, 2003: Message edited by: PewterBird ]</p>
    Cardomain
    AUDIO/VIDEO
    TV-Tuner This TVtuner does a little more than just a Tv-tuner. It also acts as a input selector and an fmmodulator. It has to AV inputs and a third for a back up cam. It also has a FM-modulator. This is good for me because I dont want to to change the headunit right now.
    Connection E This is the first connection for the video. This is the input vidoe wire for the screen. I runs all the way back down the side of the car and behind the interior to the area behind the rear passenger sail panel speaker. Here it connectst to the TVtuner Video output.
    Connection F This is the remote eye for the remote control of the TV-tuner. I mounted the eye in the corner of my dash at the base of the A-pillar. I have to have a parking sticker there for school, so it blends in nicely in the corner. This connection runs back to the TVtuner and makes a connection Between H and I.
    Connection G This is the connection for the 4-way diversity anntennas. I have mine mounted behind the plastic interior peices that line the upper hatch window. For reception the Higher the better. This was logicly the highest point on the car. They run the entire width of the top of the hatch and come down about half way down the sides. They are completely hidden from view. They use 4-1/8 minijack plugs.
    Connection H This is where the the FM-Modulator function of the device comes into play. Basicly how it works is that I can use and onscreen menu to choose th freuency of transmital. The frequency exits through this antenna wire. I capped the end of the wire with terminal hoop, and attached it to the second termnal post on the Car antenna base. Ony my power antenna, there is a terminal where the signal travels into a wire that goes to the HU. On the same bracket there is a second one, I just found a nut and bolt and connected the FM modulator antenna here.
    Connection I This is the TV-tuner output is and the Screen input is pluged into.
    Connection J This is the AV1 input for the PS. Just connect the PS1 output into this jack.
    Here are the Pics without my letters all over them.
    Cardomain
      Review
      But so far my girlfriend and I enjoy it, she watches her WB shows while I drive, and I watch (mostley Listem) the simpsons on my drive home.
      I use it when ever I wait in the car, so as far as the utiltiy goes, now it is there I use it so I guess it was worth it.
      When I comes to reception, well I would rate it a B-. Sometimes I get all the channels really good, sometimes I don't get any, but that is largely due to where I live. In Suburbia, most people have cable or satelite, so I don't think they really work to improve the broadcasting abilities. Plus there is a lot of buildings to interfere.
      Easy to install. It wasn't that hard, esp, since I had all hard parts of the wireing all ready done. Like the hot wire from the battery.
      The only thing about it, is that I keep wanting to add components. Next I will be getting either a DVD player, or a New HU, or New 7in Matching Visor monitors. In that case the one I have now will be free to anyone who promises to use it, and to pass it on when they are done with it. Just like how I got it.
      Well I am tired now, so I am done.
      If anyone want some more photos I will have them tomarrow night, because I will be getting my new custom stiched Silver firebird logo floormats, and will want to show them off.
      [ December 11, 2003: Message edited by: PewterBird ]</p>
      Cardomain
        ugh...only 1 screen??....thats a farenheit right?....cause yours looks exactly like my two ;) ....TWO!!! [img]smile.gif[/img]
        j/k looks good man....I never though of mounting the inverter there, but my XBOX is in the backseat anyways....good job [img]graemlins/thumbsup.gif[/img] ;)
        [ October 03, 2003: Message edited by: nikon ]</p>
        05' CTS-V
        00' Camaro - SOLD :(
          <blockquote>quote:</font><hr>Originally posted by nikon:
          <hr></blockquote>
          ugh......only 2 nikon?cause those look exacly like my 4
            hey i would really appreciate the screen when you change. my car's in the shop so i haven't paid insurance for the past month. im getting ready to do something like this, except with an aftermarket HU w/ aux inputs. my email is redfirebird15@yahoo.com. id greatly appreciate it. Lyle
            CAI, Flowmaster, Audiobahn Flame Q 12, 600w RMS, Panasonic cq-dfx883u, Lightning Audio 6.5 3 ways<br />check out my page<br /><a href=\"http://photos.yahoo.com/bc/redfirebird15/lst?.dir=/Red+1997+v6+firebird&.src=ph&.view=t\" target=\"_blank\">my car</a>
