Alright, when I got my car the stereo was perfect - no rattles, no distortion, PERFECT. All of a sudden, a small raddle started coming from my door (driver speaker). Kept on getting worse, finally - me and my friend ripped apart my door by unscrewing the screw in the bottom compartment of the door and unclicking that whole thing. To my dismay, the tweeter wasn't hooked up and the t's connection wire was the rattling! We could not find the connector ANYWHERE. Where the hell is it?!?! Also, we cannot snap the plastic bottom thinger back into place - did we take it apart the wrong way - if so, awww crap :(
tweeter problem
Look underneath the soft cotton lining. The color of the cotton thingy is like a mix of pink and grey and a host of other colors.Massivefirebird\'s <a href=\"http://www.cardomain.com/id/leondb\" target=\"_blank\">(leonDB) Cardomain</a><br /><a href=\"http://www.flowmastermufflers.com/cgi-bin/flowmaster\" target=\"_blank\"> Flowmaster 80</a>, <a href=\"http://www.knfilters.com/\" target=\"_blank\"> K&N FIPK</a>, <a href=\"http://www.jetchip.com/\" target=\"_blank\"> Jet Stage 2 & 180º T/S</a>, <a href=\"http://www.boschusa.com/AutoParts/SparkPlugs/PlatinumPlus4/\" target=\"_blank\"> Bosch quads</a>, <a href=\"http://www.pilotautomotive.com/pilot2dn.htm\" target=\"_blank\"> Pilot 1055 Fogs</a>, <a href=\"http://makotoautotrends.com/\" target=\"_blank\">Clear turn signals</a>, <a href=\"http://www.autoventshade.com/\" target=\"_blank\">AVS rear blackouts</a>... <a href=\"http://www.massiveaudio.com\" target=\"_blank\">2 Massive CW 12\'s</a>, <a href=\"http://www.kicker.com\" target=\"_blank\">Kicker 2252, 652,& 352 XI Amps</a>, <a href=\"http://www.mbquart.com/2003/en_US/home/\" target=\"_blank\">MB Quart</a>.
okay, sweet. ill look at that tomorrow - how do i pop my door panel back on though? It's like we try to push it back in, and it doesn't click. Just hangs there with the pink stuff exposed a lil. Any answers on that? did we take it off wrong?2002 NBM Firehawk #312 | <a href=\"http://hawk.visionsconnect.com\" target=\"_blank\">hawk.visionsconnect.com</a>
All I did to take mine off was unscrew every screw, including automatic window buttons.
To get it back on, connect the top part first, making it sit on the door, then the rest snaps on. There are little metal snap-on pins that go right in place.
If you tore the speaker panel off (like I did my first time around), you need to take the entire door panel off, and try to use silicon or any other good adhesive on the inside of the panel. If is very fragile. I glued mine back, but I need to get another left door panel to replace mine later! :(Massivefirebird\'s <a href=\"http://www.cardomain.com/id/leondb\" target=\"_blank\">(leonDB) Cardomain</a><br /><a href=\"http://www.flowmastermufflers.com/cgi-bin/flowmaster\" target=\"_blank\"> Flowmaster 80</a>, <a href=\"http://www.knfilters.com/\" target=\"_blank\"> K&N FIPK</a>, <a href=\"http://www.jetchip.com/\" target=\"_blank\"> Jet Stage 2 & 180º T/S</a>, <a href=\"http://www.boschusa.com/AutoParts/SparkPlugs/PlatinumPlus4/\" target=\"_blank\"> Bosch quads</a>, <a href=\"http://www.pilotautomotive.com/pilot2dn.htm\" target=\"_blank\"> Pilot 1055 Fogs</a>, <a href=\"http://makotoautotrends.com/\" target=\"_blank\">Clear turn signals</a>, <a href=\"http://www.autoventshade.com/\" target=\"_blank\">AVS rear blackouts</a>... <a href=\"http://www.massiveaudio.com\" target=\"_blank\">2 Massive CW 12\'s</a>, <a href=\"http://www.kicker.com\" target=\"_blank\">Kicker 2252, 652,& 352 XI Amps</a>, <a href=\"http://www.mbquart.com/2003/en_US/home/\" target=\"_blank\">MB Quart</a>.
