Ok i almost have my system. i have 2 Infinity Reference 1232w that are going to be powered by Rockford p5002 and running those is a Dual XD7500 HU! Now all that i need is a box and wiring kit got any ideas? Will that amp power the 2 Reference Subs?? thats my first question and my second is would u recommend buying a box or making one. i like to listen to rap mostly so im going to need a sealed box. please and if u know where to get a wiring kit let me know and what size should i get! i already said this but will that amp be good for my subs?
Amp + Subs
actually for rap i would tell you to look into a ported box. Its more work to build your own with ports but its the only way to do it and get it tuned right without spending a ton of money on the box. Its not that bad to make your own box either, just read up on it. That amp should be more than enough for those subs (in other words dont turn the gain all the way up). The HU is your weak point in this system and i would recomend upgrading it if you want to get any decent sq out of this system (clarion will be your best best bang for the buck). Use 4 guage wire for the amp and run it down either passenger or driver side and then your RCA's down the other side so prevent interference/distortion. good luck, with the install.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
I also got a Knuconcepts wiring kit. they got some really good kits for good prices. i got 4ga ground + power wires, 12ga speaker wire, rca's and the fuse holder for 35 bucks shipped. got it in one day.
heress a link:
http://stores.ebay.com/KnuKonceptz-c...isplayZ2QQtZkm<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
Will i blow my subs with this amp??? what shouldi do not too and how do i do it. i need some help because i am new to all of the sound system ****.!!No Worries!!<br /><br /> <a href=\"http://www.cardomain.com/memberpage/515424\" target=\"_blank\">http://www.cardomain.com/memberpage/515424</a>
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...7 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
