question for all - FirebirdV6.com/CamaroV6.com Message Board
question for all
  • question for all
    Hey all,
    I have a quick question about wiring my new sub. I’m not sure if I have this right and don’t want to risk it. I have an Alpine type R 10” sub. It’s the SWR-1042D. I’ll be powering it with a MONO Alpine amp. The amp I’ll be powering it with is the MRP-M200. Now my question is, do I want to wire it up for 2 ohm or 4 ohm? It’s going to be 1 channel mono amp powering a single 10” Alpine sub in a stealth box. The sub is a dual voice coil
    Thanks all
    Brian
    2002 Firebird<br /> <a href=\"http://www.cardomain.com/ride/2106142/1\" target=\"_blank\">http://www.cardomain.com/ride/2106142/1</a>
    Re: question for all
    You will want to wire the dual voice coils on your sub in "Parallel." Wire all the (+)'s on the sub to the (+) on the amp...then all the (-)'s on the sub to the (-) on the amp. This will create a 2-OHM load. Heres a diagram:
    2006 Tiburon
      Nda is correct.
      P.S. Your choices are 2 ohms or 8 ohms. Not 2 or 4. Just FYI.:p
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        Thanks all for your reply's
        Ok I did have it hooked up right.
