2002 firebird monsoon system problem - FirebirdV6.com/CamaroV6.com Message Board
  • 2002 firebird monsoon system problem
    i noticed the other day the the 2 speakers in the rear hatch quick working, the tweeters still work but not the speakers, i used another speaker as a tester, checked fuses, connections, tried another monsoon cd player, nothing, they will not work anymore, can anybody help me out here?
    Re: 2002 firebird monsoon system problem
    well for future reffrence if you ever want to see if a speaker is blown insted of going through changing decks and all that just cut wires and add two wires to the speaker you want to test, then connect to a 9volt battery dont matter if neg topos or vise versua but if they work the speaker will "pop" but other then that if there blown just go to the ency and check where it says how to replace the monsoon speakers cheaply or what ever hope that helps
    \"its been long over due\"
      Don't even bother replacing them, you won't hear them anyways. Mine are disconnected because they didn't work either.
      <b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
        ive never had more trouble with car audio in my life MONSOON SUCKS BALLS for real like who would even think of makin stupid 2 ohm mid speakers they sound like garbage
          the speakers arent blown i know that, i tested them, theres just no juice running to the speakers for some reason.
            replace your system, all of it, monsoon=junk every speaker will go out eventually, there is 1 monsoon speaker left in my firebird, and it is soon to be replaced after my b-day
              It's not so much that the hatch 4"ers are 2ohm as it is the amp doesn't power them, that's why they hardly make a difference. I'm replacing mine with a set of Infinity Kappas, I'll let ya'll know how much of a difference it makes pre/post amp.
              And bah, why is there just ONE Monsoon speaker left in your car lol? Is it even possible to buy a single aftermarket speaker?
              2002 Black Firebird:<br />A4, Y87, W68, T-tops<br />Best NA ET: 15.16 @ 90<br /> <a href=\"http://members.cardomain.com/darksde02\" target=\"_blank\">http://members.cardomain.com/darksde02</a>
                Did you ever find a reason why the speakers stopped working?
                I would like to know as mine have about 1% of the output
                they used to have.
                Phil
                  ur weird:banana: :banana: :spank:
                    Ummmm.... OK?:omg:
                    -Y87
                    Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
                      2 days ago
                    • Doodler
                      97 Camaro base with expensive sounding noises
                      by Doodler
                      Still trying to find oil leak
