hi can anyone tell me what size the front and rear speakers are and tell me how to take them out thanks
93 camaro
Re: 93 camaro
Fronts and Rears are a 6 1/2" or 6 3/4" dependent on the company that makes them. If you look at most american companies they are 6 3/4" its mainly the euorpean companies that call them 6 1/2". The rears, just pop the cover off, and take out the bolts, be careful not to let the clips they screw into fall... And as far as the fronts, pull the door panels, pretty simple, if you can't figure it out, you will probably break something so take some time and ask someone you know for help if you need it. Good luck.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
Re: 93 camaro
door panels are held on by several screws.
1 on triangle sail on top.
1 behind the door handle/lock peice
2 under the handle you pull the door shut with, and
1 in front of that handle.
They are all philips head screws, and depending on whether u have power or manual windows you may need a window crank removal tool.
then after all the screws are removed the door panel lifts up and out.
make sure when you put the door panel back on that all the hooks go into their holes, to secure the door panel properly, and make sure not to overtighten anything cuz they are plastic and they will break.
As for the speakers, yes, 6.5 will fit, to make things easier buy speaker plug adapters from best buy so you dont have to cut the plug off, and no splicing wires, they are like 6 dollars for a pair.
Screws that hold them in are either philips head screws, or 7mm or 1/4inch
Hope that helps.*Matt
Re: 93 camaro
Check out this thread:
http://forum.camarov6.com/showthread.php?t=40529
Including the hyperlink in the first word "here". Should answer all your questions. A trick for the back speakers? No trick. They're easy as pie.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...6 hours ago
