Some deadeners require that they be applied with a heat gun or blow dryer. Infact, I'm sure every brand would benefit from this.
I use RaamMat. Perfect.
They do even if they don't require it, it helps so much! Might even want to try that on the fatmat if you didn't do it when you installed it. Paint removing heat guns work perfect!
