Bose System? - FirebirdV6.com/CamaroV6.com Message Board
Bose System?
  • Bose System?
    I have a '94 Camaro v6 coupe, bought used a couple years ago.
    It has a Kenwood head unit. AM/FM/CD.
    One speaker in each front door. Basic paper cone.
    One empty spot for a speaker in each of the rear pillars. Plastic grills & holes, but no speakers.
    One speaker on drivers side in the back. It says Bose on the grill cover. I think it has an amp attatched right to it.
    My questions are:
    Did I read that only a Bose head unit would work with the Bose system?
    Did the car come with the Kenwood head unit stock? I dought it.
    Can the wires hooked to the back speaker be used for an aftermarket box?
    What exactly is a Bose system, & how do I check to see if it realy is one?
    What would you do for around $300.
    I listen to Country & Rob Zombie.:dj:
    Left turn Clide.
    Re: Bose System?
    i'm pretty sure if there are missing speakers, and an aftermarket headunit, that the bose has been scrapped, i would put speakers in the sail panels and componets in the doors, then buy a cheap 4 channel amp to power em, you will notice a drastic improvement
      Re: Bose System?
      $%^&$#@. I was pulling out the back Bose speaker & put a screw driver thru it. Anyone think silicone will fix it?
      Left turn Clide.
        Re: Bose System?
        i dont think its worth fixing, imo
