okay hears the deal. I'm getting clicking noises through my subs whenever i use my power windows...it's weird. and theres a constant low hissing coming from my subs too. Any ideas on a solution?? Thxs
unwanted noise!
Re: unwanted noise!
Originally posted by brad94okay hears the deal. I'm getting clicking noises through my subs whenever i use my power windows...it's weird. and theres a constant low hissing coming from my subs too. Any ideas on a solution?? Thxs
Re: unwanted noise!
Originally posted by brad94Uhmmm which is the ground wire?? not too sure? how short should the ground be??
There should be several ground wires in your system. One under the hood coming from battery to chassis. This should have been upgraded when the power wire was added. Same gauge as the power wire and as short as possible. Next, you'll have one coming from the amp(s) to chassis. Again, should be the same gauge as power wire and as short as possible. Same for behind the headunit. Although I have found some noises are cured by using a direct to chassis ground rather then the stock ground wire. Make sure all grounds are solid and metal to metal. No dirt or paint!
Another common problem for noises is when you have ran your main power wire from the battery directly next to the RCAs that come from the headunit to amp(s).
Re: unwanted noise!
You can also get feed back depending on the amount of power your using on stereo vs. the size of plug wires. I had stock wires when I first put my sytsem in and was getting a whining from speakers. I know your having problems with subs but it's just another idea. Good luckOriginally posted by kalaI'll have buttsecks with Richard Simmons!
TEAM BLACK!!!
parting her out
Re: unwanted noise!
The noise is coming throught all my speakers not just my subs. Whenever i use my accesory's (turn on my headlights, defroster, even when i change the song on my deck) it makes a clicking/thumping noise. I fixed and doublechecked all of my grounds and still does it. It never used to do it. it was only after i pulled the deck out to see what king of bulb i needed for my defroster thing cause it burned out. ???help!!
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...22 hours ago
