Ok I just bought an adjustable line output converter to use my stock head unit with my subs until I buy a new deck. I talked to someone at circut city and I completly forgot what he said. My question is how and where do I instal this??
Need help
Re: Need help
You have the monsoon?
Most generally, you just splice into the rear speaker leads. The converter has RCA outputs. Hook up the RCAs and run them to your amp.
If you have the monsoon.... you should probably hook it up behind the headunit. Before the amp ups the power to the rear speakers.
