how do you connect the RCA cables from an amp to a stock headunit? or can you?
amp on a stock H/u
Re: amp on a stock H/u
here you go read this big boy ;)
http://www.clubknowledge.com/Car_Audio_FAQ/?t131999 Mildy Modified 3.8L V6 Mustang<br />everyone in the NC triangle area should check out the forums at...<br /> <a href=\"http://www.chaoscarclub.com\" target=\"_blank\">http://www.chaoscarclub.com</a>
Good enough for what you're doing, if you want a real good sounding system, then you gotta upgrade the HU wiring and speakers. The line converter does sound good if you have a decent stock system, I installed one into my friends Explorer and its been gold since.
i know for the GTP's they made an interface to get your steering controls and the stock HU to the Bose system in them. Not sure if it applies to the Camaro's and birds though.~Cole~
P.S. Here ya go:
http://www.3800performance.com/Merch...oduct_Count=16Last edited by Cole Angrimson; 06-20-2006, 12:09 PM.2000 Grand Prix GTP- Bronzemist Metallic: K&N Fenderwell Intake,3.4\" Thrasher Pulley, v1.0 DHP PCM, 3\" Mandrel Bent DP,Ubend Delete,Dynomax SuperTurbos, 180* Thermostat.<br />Soon to come: ZZP SSIntercooler or N20 or both:)
The PAC OEM1 is the adapter you're talking about. Plugs right into the stock wiring harness and gives you RCA outs. Kinda pricey though. Think it's like 45 bucks.
The PAC SWI-X will allow your steering wheel controls to work with an aftermarket headunit as long as the headunit has an IR remote.
All of this is in the mod ency
