Just wanna know how do I wire my fog lights I bought 2 sets so I will have a total of four plus the halo rings around my halo headlights. I would like to wire them to one switch where everything comes on at the flick of a switch or should I let a stereo place install these for me
Re: how do I wire my fog lights
the install really isnt complicated, the fog lights should come with fairly good directions but all you need to do is...
Have a good ground, and make sure you have a fuse on the "hot" power wire between the battery power source and the foglights..
i went ahead and drew a simple instructions on 'paint' hope it helps you.
*Matt
yes, that is what i did, take out the headlight so it will be easy access, cut the two wires from the existing ones and unbolt it from its little hanger. take the hanger off of the foglight so you can reuse it. you'll have to find a way to mount the new foglight to it like i did, it just depends on the style you have, and CRIMP the wires dont twist and tape. if you can find a way to solder then that is best, but i just crimped mine. i'll get you pics of what mine look like when i get home tonight, but that is so much easier than trying to wire new foglights, its alot cleaner looking too. lol i have my halos on a different switch though cause i dont always want my halos and foglights on at the same time, when its dark and the only part of th car you can see is the angel eye, its mean looking. put the halo on a sepparate switch.Last edited by 1999Spectre; 06-21-2006, 09:26 AM.
