I still wish I would have had more money to spend on a nicer setup then what I have now.
the pics on my sound domain don't show the 10w7 but it's there will add pics when I get a chance. Kinda thinking I will sell what I have and use something else but I don't know at this point and time.
I had a single 12" Alpine in a center board like his setup, and I "thought" that it hit well. I then bought an MTX stealth box for the hole in the drivers side, and decreased to a Sony 10" with the same Amp, and d@mn it hits now at the same Volume. That small box made alot of difference in sound! I think if he put that sub in a stealth box, it would pound! Just my 2 cents though.
im going to get a 1 sub set up to fill up the entire well area. but my sub likes 3-4.5 ft boxes :) i think if he vented that box he would be closer to factory spec with port displacement and the fact that ported boxes generally need to be bigger.
In all reality i was just lazy and didn't wanna build a new box and false face so I just fiberglassed a trim ring in place to mount and seal the sub up.....and it actually sounds just fine.......the more power you push to a sub the smaller of a box you want as it takes more power to push the sub to it's excursion limits. a bigger box doesn't take that much power.....so instead i just turnded the gain down below max power and left the bass Eq off. i run it hard daily and still runs great.
only problem with putting this sub in a stealth box is it needs a minimum of 1.25 cubic feet sealed and it is almost 9 inches deep.....for a 10 that's insane.. the 12 was 11.5 after displacement i am sitting at 2.08 cubic airspace in the box. still to big even if i airo ported it or slot ported it but. been messing with stereo's to damn long....the longer i do it the more i want to get into the go scene. tired of alarms and speakers.....and i hate LED's.
