i know the yellow top is king of the system bateries. but will a odyssey Dynabatt work with well with a system or is it just a race car battery. i only have 620 max watts in my L7
Yellow top optima vs Odyssey batt
Re: Yellow top optima vs Odyssey batt
u dont need a better battery........
I have two 18's , Earthquake PHD-3 ampd, 5000 watts max 3000 RMS at 2 ohms ..... I have a diehard gold under the hood and a yellow top in the trunk, both runnin in para ... with a 620 watt MAX system or RMS , you arent going to need a better battery.... the amp draw cant be that much... I know a lot of people dont like caps, but if ur having head light dimmin, for ur system im sure a half farad could help u out....
Odyssey or Red Top if I were you. Then just alternator if you have problems. Yellow tops are for brute cranking amps, used mainly for large heavy spl systems, you arnt kicking 2000+ rms and full volume, I wouldn't worry about it to much. Cap, couple amps, and a red top or odyssey you would be good to go no worries.
I have 120 amps of current draw from my amps at max volume, and I run just a 140 amp and a red top, 5 farad bank, no problems at all ever.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...1 day ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 weeks ago
