seat install - FirebirdV6.com/CamaroV6.com Message Board
seat install
  • seat install
    i did a search but didnt realy find the answer i wanted
    im trying to put 6 way power seats with lumbar adn bolsters in my firebird with leather power seats and i knew ahead of time that the plugs would not fit and the guy i bought them from didnt send some type of harness that i need that connects the passenger side to the driver side power there a 6 pin wire sockets on both seats. i have a friend at a pontiac dealer ship and since the guy i baught my seats from has been deployed im tired of trying to track him down so im jsut goona get the part i jsut need tha part number so i can get it doesn anyone have any suggestion sas to where to find it when they pull it up on the computer it gives 15 different connectors wiht no pics so for you guys that have done this help me out
    no fate but what we make<br /><a href=\"http://www.cardomain.com/memberpage/748167/1\" target=\"_blank\">http://www.cardomain.com/memberpage/748167/1</a>
    Re: seat install
    O.K.
    Slow down on your words, what do you want?
    Left turn Clide.
      Re: seat install
      just find a diagram and then splice away, i wouldnt waste my money on adapters
        Re: seat install
        ok i decided i couldnt spend that much money on wiring i could do my damn self so for those who get the six way seats without a harness and dont want to spend the $112.00 it cost i suggest this
        things needed to finish job
        10 ft of tubing for the air pump 3/16 inner diameter
        4 3/16 couplers
        10ft of bundle wire (has 9 16 guage wires built in it)
        12 but connectors
        and 2 or so t connectors
        tape and crimpers or solder of you skeird
        (this will work for vehicles without power seats as well the wire is run for all even if you dont have the option but only on the driver side hense the need for the harness)
        remove seats
        unplug two prong connector on driver seat (this is the power source for the whole job)
        the wires for that will be orange and black orange being positive)
        now to run your hoses and psuedo harness if you will
        the center console must be taken out (i couldnt get my ebrake hande off so i just lifted mine enough to work under) you will have to take the shifter console off first undoing the two 7mm hex screws under the lid (mine is an auto so i dont know how you manual boys have to do this but im sure you will figure it out) take off shifter handle( dont forget the c clip in the front of the handle pull it out with needle nose pliers i lhave left mine out for years) put it into 2nd gear and lift you will need to unplug the cig lighters and the light that goes into the shift console.
        next there are 5 10mm bolts holding the whole center console down, 2 in the center console compartment 1 under the shifter panel and two under the radio at the sides. once loosend lift console and wedge something under it for support ( i found the seatbelt ends worked well).
        run your wire under the carpet through the slits already provided ( the harness wire is kinda think so it will be difficult but when i did it mine runs under the air bag module but that was just easier for me you can do it how ever you like) 10 ft wil give you plenty of extra should you need it. also run your air hoses with couplers installed (they are very hard to put on but that is what you want to insure no leaks or them blow apart due to pressure) you will have to cut off the connectors of the tubes from the seat to do this ( only cut the ones not connected from the compressor on the passneger side seat that is the one that runs to the driver side so you want to connect those 2 otherwise the passenger is the only one that gets to enjoy the seats
        next on the new seats you will notice that it is a 6 pin plug consisting of orange red pink purple gray and black wires on both seats. you now have to power wires coming up out of the carpert for the original seats (the 2 pin connector with orange and black wires) use the t connectors and splice the orange and black from the car to the 6 pin orange and black on the seat to your new harness(note these wires will not be color coded so it is important to decide how to match them before you start to cut for example the bundle wire will have 9 indiviual colored wires in it pick the ones you want and match them to the colors on the seat plug use your descrection, but write it down so you dont forget) you should know have power to the six way switch and nothing else remember all we have connected thus far are the orange and black wires to each other and the new harness.
        now take your male and female connectors crimp them to both sets of wires from the seat plug to your new harness( you will be connecting the red pink gray and purple on the driver side and then all of them on the passenger side)
        connect your air hoses and test her out before you bolt them down and you will now have power seats and passenger and driver lumbar and side bolster support.
        sorry for the lack of pics but i didnt take any when i was doing this at 2 in the morning but if you have any questions feel free to ask and i hope this helps those that needed this info as it was not readlily available
