go into your headlight switch. Using a testor, find the wire that NEVER has power, hook up your black wire to that. next, find the wire that does not have power when the switch is in the 'off' position, but does have power when it is one click over, the parking lights. Tap the red wire into that. the box is a 'glow inverter' and it has several 2-prong clip connectors for other accesories such as illuminated racing pedals. I installed some of the reverse glow gauges last month and that is what i did, worked good when i got it right. good luck
troy
