last night on my way home i noticed that my bass suddenly got quieter.. when i got almost home i finally relized it was cause one of my subs quit workin! i have 2 12P3D4 subs... i checked all the wires and everything and it still isnt working... any ideas? thanks
sub quit workin! help!
Re: sub quit workin! help!
i did.. the other sub works... its just the one sub that quit1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
i checked wires from amp to box... inside the box to the sub... and the rcas on the sub... its a hifonics zues 1205d i think thats the model number... i dont see why one would keep playin fine and the other just go out like that1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
how would i know if i blew a channel or a voicecoil?
i just went and pushed in on both subs and they both had the same give...
i dont think its a channel cause my wires on the amp are in parrallell or whatever you call it... i took the wires goin from the amp to the good sub and put them on the other and it still didnt work.. so i guess i did blow somethin in it... any suggestions on what it might be or what i should do about it?1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
i guess i have 2 options.. i can either replace the sub and have the same setup.. or sell the good one and upgrade... what would be better in ya'll opinions.... 2 P312D4 subs or 1 T115D4 sub? theres only 100 w diference in the RMS but i bet it would take a lot more with no problems1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
Disconnect the sub at the speaker. Attach any other speaker you have, raw or some small home speaker. If the speaker works fine then its not the sub.
Never, ever push the cone back and forth, that is a good way to push it out of alignment and get the piston to rub and then the sub is truly done.
Check fuses to see if they are okay on the sub amp.
Get meter to see if amp is getting twelve voltsPhil
all thats fine....both subs were on the same amp.. the other sub works like nothing happened... i switched the wires goin to the subs to see if it was the wires and it still didnt work.
what do u mean disconnect the sub at the speaker?1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
