question for install - FirebirdV6.com/CamaroV6.com Message Board
  • question for install
    ok well can someone give me a good link for installing this
    Amp: 400WRMSx1@2ohms
    http://cgi.ebay.com/NEW-PIONEER-PREM...QQcmdZViewItem
    Sub: Dual 4 ohm 350WRMS
    http://cgi.ebay.com/PIONEER-TS-W256D...QQcmdZViewItem
    WAWA-A-HOLIC
    Re: question for install
    links not working
    but good choice with the pioneers, better than what you were going to buy before
      Linx don't work on here either...
      I don't know crap about stereo stuff, but this helps my post numbers:banana:
        what is your quetion about the install? let us know so we can help you out more. do you need to know how to wire it together? how to install the system itself?
        Dave:
        00 Supercharged Camaro - RIP
        97 Turbo Camaro - Sold
          If you're looking on how to wire the sub to the amp, which i think you are, the best site i've found is
          http://www.sounddomain.com/shop/woof...dvc&x=102&y=10
          This should help.
          Check out my car on cardomain.com!!! <br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=844739\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=844739</a>
            sorry the question was how to wire the sub to the amp, and then how to connect that to the head unit. and what kinda wire i need
            WAWA-A-HOLIC
              Believe me...I don't know this area too well! ...but, this is how I did my amp:
              -I used 8 ga. wire to power the amp, I ran it from the battery with an inline fuse
              -Used 8 ga. wire to ground the amp. Ground wire being as short as possible
              -Monster RCA Jacks from the HU to the amp
              -Monster Speaker Wire from the amp to the speakers (or in your case, the subs)
                is there some kinda kit out there?
                WAWA-A-HOLIC
                  Oh God yeah! They are all over ebay, or you can just go to Best Buy, Circuit City, etc. You can find kits, or you can buy them all seperately.
                  I bought a 20ft. power cord, 16ft rca jacks, and a 3ft ground cable. All seperately for about $60 (or more...I forget).
                    I always recommend atleast 4g for anyone adding a subwoofer. Usually only a few more bucks then 8g and leaves you room to upgrade in the future if you decide.
                    www.knukonceptz.com
                    www.darvex.com
                    www.ebay.com
                    Check out this one= http://www.knukonceptz.com/productDe...?prodID=eKo-K4
                    You also need some way to connect the power/ground wires to your battery. You have side mounts on the battery? Grab a pair of these:
                    http://www.knukonceptz.com/productDe...fm?prodID=GMBT
                    And I already posted a diagram of how you want to wire the subwoofer to the amp. For a step by step walkthrough on the amp install, check out our sticky.
                    Red 96' A4 Firebird
                    Audio Audio and Autotek
                    Check it out here!
