sound deadener - FirebirdV6.com/CamaroV6.com Message Board
sound deadener
  • sound deadener
    how many sq. feet do i need to do the whole car? i wanna do the whole trunk, the trunk lid, the floor panels all the way up to the firewall and the doors and the ginormous b-pillars and the little bit of roof just behind the t-tops. i was thinking i can get 40 sq. ft of second skin's damplifier for like 100$. if i need more i can get like 60 feet of RAAMaudio's RAAMmat BXT for like 120$. i chose these two cuz they won the sounddeadener showdown beating out even dynamat xtreme.
    2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
    Re: sound deadener
    i got 200 sq feet for my entire car (my old 94)..... but i did it 2 layers thick, entire thing.... i was left with about 20 sq feet... so id guess to do the entire car one layer, around 100... not going crazy, 50
      Re: sound deadener
      how much of a difference did it make? was it like night and day?
        Re: sound deadener
        do you have your RCA cables taped to your power wire big tymer?
        You supposed to run them on seperate sides of the car... do you get alot of interferance?
        *Matt
          Re: sound deadener
          in the entine car and doors and trunk i used about 135sq ft sofar single layer. get atleast 100sqft and start at the fire wall and work back. make trunk and doors last incase you run out you will not have to pull the carpet twice.
            Re: sound deadener
            go with the btx. rick from raamaudio will give u a discount if your a member of elitecaraudio.com plus his customer service is unlike anyother.
