GRRRRR: how do I remove the antenna cable? - FirebirdV6.com/CamaroV6.com Message Board
  • GRRRRR: how do I remove the antenna cable?
    I'm taking out my stock head unit, but the damn antenna cable won't seem to come out. I tried pulling it a little, then screwing it and it doesn't want to come out. How do I take it out of the stock head unit?
    Also, do I need an antenna adapter, and will I have to do any wiring work if I buy a wiring harness for the head unit??
    Re: GRRRRR: how do I remove the antenna cable?
    as far as I remember the ant. just pulls out and yes you will need the adapter (thanks GM) as for the harness if you are asking what I think you are the harness plugs into the car harness and you still have to wire it up to the head unit... hope this helps
    Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
      Thanks, that does help. I'll just yank the mother f***er then.
