got a question....i have 2 12in l5's on the way...the rms is 600w and the max is 1200w...does that mean i could run 1200 to both of them or should i run one 1200 watt amp to both of them?
rms vs max
Re: rms vs max
run 600 watts to each one... i dont really know what would happen if you gave them each 1200.. but it prally wouldnt be good.. lol1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
Re: rms vs max
here's a excerp from glasswolf.net
So you've seen speakers that say "1600 watts" and you think to yourself, where am I going to get an amplifier and the charging system to feed it for a sub like that?
Well, let's answer some common questions and clear up a few even more common misconceptions about power handling specs on speakers.
A speaker usually has two power handling ratings. RMS and Peak or Max ratings, measured in watts.
I would first like to point out that these ratings are thermal ratings. This means that the power ratings are meant to tell you how much heat a speaker's voice coil(s) can handle as measured in watts, without incurring damage. It is important to realize that this has no relation to the amount of power the speaker actually needs to reach it's peak mechanical output. That amount of power is generally less than what the speaker "can take" and is dependant on both the speaker's design as well as the enclosureinto which the speaker is placed.
Defining RMS and Peak power handling:
RMS (more accurately called continuous power handling) is the measure of how much power the speaker can enfure for extended, continuous periods of use. This is an average rating since music, and thus the power required to produce it, is dynamic in nature and varies greatly from moment to moment depending on the frequency being produced and mechanical characteristics of the amplifier and speaker.
When pairing an amplifier and speaker or speakers, you should try to match the amplifier's power output to about 80% of the RMS rating of the speakers, at the load they'll present to the amplifier. This is a good, safe region to aim for if you're unsure of how much power the speakers actually need, and is a very generalized rule of thumb.
Note that RMS ratings for speakers apply to a clean, AC voltage being applied to the speaker. If the signal is clipped in any way, the resulting DC voltage will cause the coils to heat more quickly and to greater temperatures, causing damage at what may be an amount of power well below that of the RMS rating.
Peak ratings are strictly meant to tell you how much heat the voice coils of the speaker can take for a brief, momentary burst of power without essentialy blowing apart the speaker or melting the coils on the spot. This measurement isn't very useful in real world application so it's best left ignored for the most part.
In conclusion, please keep in mind that just because a speaker may say it's rated for 2000 watts RMS, that by no means implies that you actually need that much power to get full output from the speaker. In fact you may need as little as 300 watts RMS to achieve peak excursion in teh right enclosure. This is a common misunderstanding by a large contingent of the car audio world, and one well worth addressing. This is why many people will tell you that you don't always need thousands of watts of power to have a loud systemLast edited by kala; 09-14-2006, 10:33 PM.
Re: rms vs max
Find a mono 1200WRMS @ 1ohm amp if they are both 4ohm models. This will provide each of them with 600WRMS.<b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
Re: rms vs max
Originally posted by patrick3800oh ok thanks....i ordered a hionics brutus 1200w at 1 ohm........ and i wasnt sure what i needed....it was a good price so i ordered it , will this amp work with 2 4ohm 12in l5's? if not i can always send the amp back<b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
