I got out of stereos for a while, but I decided my factory stereo needs a bit more punch. I bought a 8 inch powered Bazooka tube off ebay for cheap. Oddly enough I have the Monsoon deck, but not the amp or rear subs. The previous owner must have upgraded the deck or something. Anyways...My question has to do with the high level inputs. The instructions on the internet says I don't need to hook up the negative speaker wires...only the left and right postive to the high level input. Does that make sense to you? Will it work right? I was also curious as to where I should mount the sub. Thanx in advance.
Bazooka questions
Re: Bazooka questions
If you dont have an amp it wont do much better.
Are you sure you dont have the amp..i didnt know till 2 months after i got my car...its in the back wheel well by the spare tire and jack spot, all you can see is a blak plate and wires going to it.
The back subs are just the mid speakers next to the backseat passengers head.
And if you want to connect it with no amp just splice into the wires connecting thos back subs i was talking about, there should be a black wire and a red wire and there should be a black and red wire input on your sub.
'66 Ford SOLD
Originally posted by FireBird_Fr3akIf you dont have an amp it wont do much better.
Originally posted by 3.4 slow to gohigh level is the speaker wire from the head unit. low level would be the rca ( which you already know)
