Room stereo - FirebirdV6.com/CamaroV6.com Message Board
Room stereo
  • Room stereo
    This isnt car audio related but here i go...
    Ok, i have dual 12" subs in my room hooked up to my kenwood reciever, and it sounds great but i want a little more. Ive heard of people doing this before, but i was wondering if anyone had ideas of how to wire up an amp to use in my room. Ive asked someone before and they said computer power supply and i was just wondering if there was somthing cheaper?
    '66 Ford SOLD
    Re: Room stereo
    Pretty certain a computer power supply is not going to be able to provide that amp with the current draw it requires. You would need an AC to DC power supply. They're not cheap for the amount of current you will be drawing. (Well over $100) You'd be much better off buying an amp for home audio 115V AC.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      Re: Room stereo
      What about a plate amp, these are for home use but i never knew how you would use them.
      Dayton HPSA1000
      [300-808] MSRP: $599.99
      Our Price: $379.99
      You Save: $220.00
      One of the most technologically advanced subwoofer amplifiers on the market!
      This new subwoofer amplifier is based on state-of-the-art Class G circuit topology that combines the proven high power, high fidelity characteristics of a Class AB amplifier with a patented tracking down converter power supply to achieve an operating efficiency up to 86%. You get the efficiency of a Class D amplifier without compromising audio quality and reliability. The class AB output stage provides the clean and low-distortion sound that audiophiles demand, without any instability problems of other high-efficiency amplifier designs. This American designed and engineered amplifier uses patented circuitry that continuously tracks the input signal to modulate or control the voltage available to the output stage. This "tracking" capability delivers the exact amount of power based on demand instead of constantly keeping it in reserve, so the output stage only draws the amount of power that is required at any given time. This means less energy is wasted as heat, and more power is available for the subwoofer driver.
      Features:
      High power class AB output stage
      Patented tracking downconverter power supply
      Full parametric bass EQ
      Low-pass crossover: 30 - 200 Hz, 24 dB/octave
      Phase reversal switch
      Advanced soft clip circuitry
      Toroidal power supply transformer
      Auto On/Off
      Specifications:
      512 watts RMS @ 8 ohms
      1024 watts RMS @ 4 ohms
      Signal to noise ratio: 98 dB (A-weighted)
      Dimensions: 11-15/16" W x 11-15/16" H x 5-1/4" D
        Re: Room stereo
        ^^ That looks nice but, spendy.
        There has to be an easier way, how do they do it at the electronics stores? Anyone know of someone who works there or does work there?
        '66 Ford SOLD
          Re: Room stereo
          that was the most expensive one on that site lol
          if you want cheap heres some
          Bash 300S MSRP: $299.99
          Our Price: $129.90
          You Save: $170.09
          BASH patented amplifier technology was developed to offer extreme amounts of power without the wasted heat and energy of traditional amplifier designs. Add to this an intelligent circuit design, and you get benefits such as extremely low distortion and high signal to noise ratios. The combination of clean output and high power makes the BASH amplifiers some of the best sounding subwoofer amplifiers on the market.
          Features:
          50 to 150 Hz Low-pass Crossover
          0 Degree or 180 Degree Phase
          Line Level Inputs
          Speaker Level Inputs
          LFE Input
          Master ON/OFF switch
          Auto ON/OFF
          Limiting Circuit
          Specifications:
          300 Watts RMS @ .5% THD @ 4 ohm
          Signal to Noise Ratio: 105 dB (A-weighted)
          Dimensions: 11" W x 7" H x 3-1/2" D
          Bash 500S MSRP: $399.99
          Our Price: $209.99
          You Save: $190.00
          Features:
          Line Level Inputs
          LFE Input
          Auto ON/OFF
          Limiting Circuit
          Specifications:
          500 Watts RMS @ .5% THD @ 4 ohm
          Dimensions: 12" W x 8" H x 3-1/2" D
            Re: Room stereo
            You should go to an electronics store and see for yourself. Just don't ask the sales rep any questions (their lack of knowledge is generally overcompensated by their motivation to sell).
              Re: Room stereo
              I have, he was like "uhh idk" then he points me towards the receivers, lol:spank:
              '66 Ford SOLD
                Re: Room stereo
                I worked at a car stereo shop. The display board was powered by some kind of transformer. It was a sealed metal box about 16" squared and weighed 40lbs. I am sure this is a much more expensive route than what was already mentioned about getting the AC/DC converter.
                  Re: Room stereo
                  you're best off going to bestbuy or another electronics store and buying a powered subwoofer. I have dual 12"s on my floor speakers but the bass output isn't that great because of the amp. So I bought a 10" 100W sub for like $150 and the power output is great, i can shake the house and be heard blocks away.
                  1996 Chevrolet Camaro
                  1995 Buick Park Avenue Ultra
                  --Appearance Moderator--
