optimal amp settings - FirebirdV6.com/CamaroV6.com Message Board
  • optimal amp settings
    I would like to know some good frequency settings,
    crossover, and V Level (I guess this is Low input?)
    sorry, i know i should go read
    Re: optimal amp settings
    i keep my LPF around 90, i listen to a mix of rock/rap, and ive found that 90 is a good mix for both. I only have the amp turned a little more than half way up.
    Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force's
      What is the amp powering? Subwoofers? And yes, you should read your manual. I have no idea what "V level" means. Could be many things.
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        i think the amp is like 200 watts 2 channel of course
        the subs can handle like 230 watts
        no manual but maybe i could find one
          you are talking about GAIN?
          which deals with the combing of the Head Unit and the amp.
          If the Head Unit is low output.
          I read how to set the gain up, thats easy.
            This is the email I just sent Crossfire, which they probably wont respond to:
            I have the vr202 and was wondering what would
            be the optimal setting for the FREQ. in (hz)?
            It goes 50-500 on the vr202
            I guess this has to do with the lowpass/highpass crossover.
            Which mine is set to LPF because I have the 2x 12" subs
            (which of course my amp is a 2 channel)
            I have it bridged
            Attatched is my wiring config
            Thanks alot!!
            please help
              on a seperate note:
              what would you use a processor for? like a crossover/graphic equalizer?
              would you really need all that control?
