eD Rear Speakers - FirebirdV6.com/CamaroV6.com Message Board
eD Rear Speakers
  • eD Rear Speakers
    Ok i saw a guy on car domain with these replacing his rear 6.5 speakers
    http://www.edesignaudio.com/edv2/pro...products_id=33
    how would they be able to fit?
    EDIT:Would they fit with no mod?
    '96 Trans Am M6:) Cam, lifters, 1.6rr, lt4 springs, 4 bolt mains, long tubes, TDs, short throw...etc
    '99 Firebird SOLD 1/4 mile 15.4 @ 86
    '66 Ford SOLD
    Re: eD Rear Speakers
    And would they hit harder than a 10" type R? i would think so b/c they're 300watts rms each,
    '66 Ford SOLD
      Hey i got your post in my guestbook over a cardomain. I was able to get the eu-700 to fit except the holes (on the eu-700) to mount the speaker had to be drilled a little to match the holes in the body panel. Also used some think plastic washer to mount the speaker out a little since it would not mount flush due to a huge magnet on the back. Got this intall idea from a writeup someone had done but cant find it anymore. I've got the eu-700's for the mid and edi-6500's up front powered by a nine.4 amp and an alpine 9851 HU. They sound awsome, compared to my factory blown monsoon system. I've got some edead to put in to help with sound deadning. If you have any questions let me know. I'm no audio pro though.
      Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
        Im not familiar with other brands but check out the Excursion Video of the eu-700 http://www.edesignaudio.com/edv2/eu700.php . I dont turn mine up too loud from the fear of the sub hitting the plastic panel it goes behind. I need to flush mound these but I dont think flush mounting can be done. Maybe a thinner washer to get them as flush as possible.
          If you want to save a little on eD gear, call me. I can probably also make some adapter rings to adapt camaro rear speaker mounts to fit the EU700s.
            Do these go in the hatch panels, or the between the front and rear seat panels? How much could you get me 2 of them for, and how much would you want for the adapters?
            ~97 3.8L V6 Camaro~
            A few things
            Only Member of Team Hooker?!?
              X2 :) .
              '66 Ford SOLD
                if you are a forum member over at icixsound you can get fourm discounts. I think they got them for $45 right now
                  Im a member there where do i go? Got a link?^^
                  '66 Ford SOLD
                    Same question here. I just sold my previous set-up, to buy some go-fast parts.....now I want it back, but kinda want a stealth install kinda thing.
                    EDIT: Went to register, and at the top of the page, there's a link for 20% off eDead. Maybe he was thinking of that, and not subs. The code is eDeadBA for the discount.
                    EDIT2: Here's the subs, with the forum discount Here's everything else you can get a discount on
                    ~97 3.8L V6 Camaro~
                    A few things
                      Thank you very much!! ^^
                      '66 Ford SOLD
                        NP. Was doing a search on their forums, and it seems like people are having problems putting those in. I'll most likely just buy them and make them fit by fabbing up a custom bracket and doing some cutting, but I like to see what others have done.
                        ~97 3.8L V6 Camaro~
                        A few things
                          Well for $45 each I already got 2! lol
                          '66 Ford SOLD
                            If you send them to me, I'll mock you up some brackets and such :naughty:
                            I, however, cannot guarantee that they will return to you in proper working order, I'd play them as loud and as hard as I could:banana:
                            ~97 3.8L V6 Camaro~
                            A few things
                              lol, naw. But i will tell you how they sound:)
                              '66 Ford SOLD
