98 Camaro 3.8 V-6 IAC Wire Connector Diagram - FirebirdV6.com/CamaroV6.com Message Board
  • 98 Camaro 3.8 V-6 IAC Wire Connector Diagram
    Does anyone have a wiring diagram for the IAC wire plug connector. This is for a 98 Camaro 3.8 V-6. I need to know which of the following wires connect to the A,B,C & D pins on the IAC valve. The 1749 Lt Green/white, 444 Lt Green/Black, 1747 Lt Blue/White & 1748 Lt Blue/Black. I also need to know how the A,B,C & D pins are situated on the IAC valve. Meaning, with the IAC valve installed, does the A start at the top, bottom, inside second from the right and so forth. I had someone build me an engine harness for a conversion and I think the wiring to the IAC is mixed up. You can email it to me if you prefer at this email address: Chevyone@hawaii.rr.com Thank you for your support, Tommy.
