i was wondering if its normal for a 96 firebird to not have the acc mode to listen to the radio w/out having the key on and not havin to worry bout it goin off cuz my car wont do that and i have to keep turning the key on over and over again to keep the radio on can someone tell me if this is normal or not cuz i dont like it at all...:mad:
starter switch
Re: starter switch
You should be able to turn the key to the backwards position to play the radio. It should also stay on with the key in the on position with the car not running. My 97 will also play for ten minutes after I take the key out if I keep the doors closed but I'm not sure if the pre-97's will do that.
Re: starter switch
Originally posted by ChameleonGreenYou should be able to turn the key to the backwards position to play the radio. It should also stay on with the key in the on position with the car not running. My 97 will also play for ten minutes after I take the key out if I keep the doors closed but I'm not sure if the pre-97's will do that.
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 weeks ago
