Quick Question (again) - FirebirdV6.com/CamaroV6.com Message Board
  • Quick Question (again)
    Well, finally got my subs and amp hooked up. But, whenever I turn off the HU, switch from radio to cd (or vice-versa), or move forward in the CD, my subs will play constantly. When i turn off the HU, it does a good bye thing, and hen shuts-off. Once it shuts off, it's all good and they turn off, but while it's doing the bye thing, they sit there and blair(sp). What wrong? or is it my HU? It's a JVC not sure on the model # ATM, but will get it tonight.
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
    Re: Quick Question (again)
    What you are sating is kinda hard to understand.
      Do your subs start blaring with deep pulses of bass, or the music that is playing as you go to turn if off starts blaring?
      If the music is getting loud, check your power wire and reset your cd player. If it is deep pulsating bass thumps, then you need to check your rca cables for any burn marks on them, or possible cuts in them(replace, and see if the problem stops.)
        It sounds to me like it could be either a weak ground: try metering your ground location and make sure it is reading a strong ground, if not try a new ground location. You may also be having a power interference problem; the fix to that is a noise filter, or make sure your RCA's aren't ran too close to a main power wire.
          it'll play just deep pulses of bass. I'll check my ground. As for the RCA thing, my RCA's are about 2ft long. My HU doesn't have RCA outs, so I bought a line level converter and spliced into the back speakers. The previous owner had already done something similar to this, so it was very basic, and the wires were already ran. I've got speaker wire coming right to the edge in the back (before the well), then I hooked up my Converter there and plugged in my RCA's. It sounds freaking incredible, but I'd like to be able to skip songs on my CD without heering constant bass until it reads the next one.
          ~97 3.8L V6 Camaro~
          A few things
            Sounds like a bad amp ground to me. Also, let me guess..... you're using an ign +12V source for your amp's turn on signal? You have a firebird?
            EDIT: And you're in Vero Beach Florida? I'm in Melbourne. If this really gets out of hand, lemme know.
            Red 96' A4 Firebird
            Audio Audio and Autotek
            Check it out here!
              I've got a 97 Camaro. I'm using the light blue/white wire from my HU for the turn on signal. And ya, I'm in VB FL. We should get together sometime man, be kewl to meet another local F-Body owner
              ~97 3.8L V6 Camaro~
              A few things
                Make sure amp ground is super solid. Bare metal to metal. No paint or dirt.
                Actually, just sold my f-bod. Bought a Mazda RX8. May have sold the car, but the knowledge didn't go with it!:banana:
                Red 96' A4 Firebird
                Check it out here!
                  OK. It's not my ground. I thought I had it fixed at first, but realized my amp was turned off :P. Any other suggestions? Im trying to get a sound/video clip to show you guys, but I can't get on my other PC with the software ATM.
                  ~97 3.8L V6 Camaro~
                  A few things
                    There's my subs playing. I was very surprised at how loud they are. The camera's sound quality is horrible; in the vid they sound bad, but in real life they're amazing. I'm uploading more pics and another vid as I type.
                    ~97 3.8L V6 Camaro~
                    A few things
                      OK. Here's the video of the subs messing up. You can hear it at 10 seconds, 20 seconds, and then 25 seconds. The first 2 are from me changing the song, and the last is from me shutting off the HU.
                      Here's the subs:
                      Amp:
                      Crappy HU:
                      JVC KD-S10
                      ~97 3.8L V6 Camaro~
                      A few things
                        O Wow! Thats a little more than I can fathum. Maybe another stereo gureu can help you out.
                          96firebird311, u got AIM man? I'd like to meet up sometime and see if you can help me out some.
                          ~97 3.8L V6 Camaro~
                          A few things
                            weak!!! lol jp but did I told any one I finished installing my Solo-X? yeah it's pretty loude and ill be making video when i borrow a camera from my cuz stay tune.
                              Like I said, it sounds real crappy in the video. It gives me headaches in real life.
                              ~97 3.8L V6 Camaro~
                              A few things
