Ok I searched and didn't find and answer so here go's. I have an amp already wired for my subs but now I want an amp to power my speakers too. Will I have to run a second power line from the batter or can I just use the existing power wire?
Two amp hook up?
Re: Two amp hook up?
Originally posted by 4thgenownerOk I searched and didn't find and answer so here go's. I have an amp already wired for my subs but now I want an amp to power my speakers too. Will I have to run a second power line from the batter or can I just use the existing power wire?~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
You will need to know how many amps you are drawing now, how many amps the second will draw and what size wire are you using. As long as your current power line can handle the total load plus 20% you are good. Make sure you use MAX amp draw.2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
i had a 2000 watt amp and a 500 watt amp in my old car, and I simply cut back the rubber coating on my 2 gauge wire, inserted a 10 gauge for the 500 watt and put a **** load of tape over it (all that after my capacitor) Kinda ghetto but got the job done w/ no incident
You can but a splitter but I couldn't find one that could hold the 2000 watt amp1999 Camaro Z/28
1973 Firebird Formula
