Hello I'm new to the forum. I noticed that my front turn signals and hazards are not working. I have a 99 camaro. Everything looks fine from inside. The instrument panel turn signal indicators flash and the annoying clicking sound is there. When I turn on the hazards, both rear hazards flash, buth the fronts don't flash. If I turn on the either turn signal, the corresponding rear bulb flashes, but the front doesn't. After I noticed the problem I replaced the turn signal bulbs on both the front lamps. All four lights(2 on each side) will come on steady, but they won't flash. Any help would be greatly appreciated.
front hazard/turn signal problem
Re: front hazard/turn signal problem
As far as I know there are 4 bulbs (2 3157s and 2 194s) that make up the drls and turn signals in the front. All four bulbs would come on steady but the turn signals/hazards won't flash. So I replaced all four bulbs just to make sure that its not a bulb issue. Replacing the bulbs didn't help the problem. The rear turn signals/hazards work fine.
My understanding is that the left turn signals (front and rear) should work in unison and the same for the right side. Is there any reason the fronts won't flash, but the rears will? Why will they come on steady when I turn on parking lights but not flash when I turn on the hazards or use the turn signals?
