Not sure if this is the right spot for this but, I'll go with it anyway. The battery is always getting dangerously low when I come to a complete stop. The lights dim, the blinker slows down, and my heat slows too. It seems like the alternator isn't charging it or whatever, because everytime I step on the gas a little it will go up, and everything will start working normal again. I haven't really looked into it yet but if someone can give me a start on what to check or if they know what it is, it will be very helpful. Thank you.
Battery Problems
Re: Battery Problems
Sounds like your alternator is about to kick-the-bucket. The alternator basically runs all of the electrical system(s) when the engine is running. The battery is there just to start the car.sigpic
a fully charged battery will read 13.6 volts on a voltmeter and will not drop below 8 volts when cranking the engine
Do you have any extra electrical accessories...like an Amplifier?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
could be a bad battery drawing hard on the alternator try to recharge.
check your connections if the amp & batt are new2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
are you gonna repeat everything I say? lol2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by slow6are you gonna repeat everything I say? lol08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
most cars are running maiily off the batt when idling because of the way there wound(to put out more amps at crusing rpm) a fully charged batt is 12.6 any higher is a surface charge that will disapate fairly quickly. soorry for any typos i dont have my glasses on and can hardly read the screen
