just installed - FirebirdV6.com/CamaroV6.com Message Board
just installed
  • just installed
    i recently just installed a new head unit and it wont play cd's all the wires are hooked up correctly and every thing anyone with suggestions or ideas?
    Re: just installed
    without more info, we can't help you. Either faulty cd player, wired wrong, speakers wiring wrong, does it have power? does it play am/fm? etc....
      Re: just installed
      it has power and plays fm/am radio. i will check the wiring again but im pretty sure that its not that.
        Re: just installed
        did you try a burnt cd or one you bought off the shelf... some cd players won't play burnt cd's. Does it say error, or anything at all. Other then that, i'd say you got a bad headunit.
          Re: just installed
          i tried both burned and a one from the shelf but ill check all the wires tommrow n see if n e thing is wired wrong
            Re: just installed
            What kind of radio? Stock? Aftermarket?
              Re: just installed
              aftermarket
                Re: just installed
                My stereo wont play burned CD's in the mp3 format. All I had to do was go into my burning software and switch the format from mp3 to music cd and I was good. But it sounds like your problem may be just a bad head unit.
