Subs Problem - FirebirdV6.com/CamaroV6.com Message Board
Subs Problem
  • Subs Problem
    Starting Friday night, I noticed my subs would randomly stop working. They would all of a sudden stop, then randomly come back. For the most part they would stay on and cut out once in a while. Over the past couple days it has gotten worse and now it's the other way around. They stay off and randomly come on only for a couple seconds here and there. I just took out the headunit to make sure the wires were completely in, and also checked to make sure the wires were completely in on both sides of my box. When I was checking, the subs didn't come on once. It appears they have stopped working all together now.
    Any suggestions on anything else I can check? I didn't put the subs in, I had ABC Warehouse install them a year ago. Anyone maybe have an idea of what's going wrong?
    If needed I just have two P1 Rockford Punches (400watts each) and a Kenwood 800watt amp. Both were a year or two old when I bought them used from a guy. I've never had one problem up until Friday.
    Any help would be greatly appreciated!
    Thanks
    Black 1998 Camaro<br /> <a href=\"http://www.cardomain.com/ride/2300862\" target=\"_blank\">http://www.cardomain.com/ride/2300862</a>
    Re: Subs Problem
    Hey, I've got the P1's too. They're rated at 300W, not 400W, just to let ya know. Anyways, sounds to me like you have a bad connection somewhere. I had the same problem a few days ago, and it turned out to be my Turn-On wire was loose. Tightened it up and works like a charm. I'd say double check all your wires. Pull the subs out and make sure the wire's are still hooked on them too. What HU do you have? Also, check your fuse, you may have a bad one that kinda eventually died on ya.
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
      Re: Subs Problem
      Alright, I'll make sure I check all that stuff. And what is HU?
      Thanks for the help!
        Re: Subs Problem
        The Head Unit. The CD player/Cassette Player/AM-FM Radio or w/e you have as your main source of tunes.
        ~97 3.8L V6 Camaro~
        A few things
          Re: Subs Problem
          Ohh ok lol...I just wasn't gettin' it...but I have a Pioneer DEH-P7700MP
            Re: Subs Problem
            Fuse on the amp, ground wire somewhere.
              Re: Subs Problem
              i had this poblem once it is a conection. what happened my mine was the positive termanal inside the box from the speaker to the positive termanal on the box came loose. if that isn't it try the trigger wire from the head unit to the amp. good luck
                Re: Subs Problem
                Thanks for all the help guys...I'll just have to check everything this weekend. At least it sounds like it's just a loose connection somewhere so I won't be spending any more $$$
